Thanks for that, I'll make sure I always clean my new records before any first play, just a simple anti static brush micro fibre type brush is enough right? thanks.This blog has some good info about this subject...
http://www.soundmattersblog.com/why-should-clean-new-vinyl-records/
Sounds like you need to make it anti-static anyway using the brush? I have a spray vinyl record cleaner. thaty will be alright? microfibre clothThe record brush is only for superficial dust, it won't get the mess out of the grooves. And often there is a lot of crap in the grooves that shouldn't bet there and affects the sound, even (or especially) with new records.
Not everyone thinks so, I'm not going now either on my new vinyl, read what Steve Hoffman says... http://forums.stevehoffman.tv/threads/cleaning-new-vinyl.43387/Even brand new vinyl should be cleaned.
http://audiokarma.org/forums/index....d-brush-was-the-problem.774820/#post-10618007 maybe nothing is best or I'm leaning towards a slightly dampened microfibre cloth and a gentle wipe and that's it.This blog has some good info about this subject...
I highly doubt that you'll ever find (regardless of how hard you might look) any question, on any subject, where the conclusion is that "every one thinks so."Not everyone thinks so
However maybe an anti-static brush on first spin would be a good idea still as that won't leave any residual matter?
I don't have any dirty (visible) vinyl, and I wish there was a record cleaning service here where I live just in case so I can't justify buying a machine I have stylus cleaners instead haha. how can you remove static without a brush or a record cleaning machine? Thanks.These brushes will only remove some dust on the surface, they won't do jack against any of the dirt that resides in the grooves or against static on the record.
When it comes to record cleaning machines, there's an easy way to find out for yourself: Find a hifi shop or record store that has one and have them clean a couple of your records. I would not want to be without mine anymore, the difference is huge.
https://www.turntableneedles.com/Pfan-Stat-LP-Vinyl-Record-Cleaning-Fluid_p_2825.html^^^ Can you procure a vintage Discwasher? They do a good job dry, slightly better when damp along the leading edge. My really old records that I had before Discwasher's were common, sound much worse than records that were cleaned/dusted with one from the beginning. On new records a Discwasher should at least prevent any real damage from being done. If you can get the Phan-Stat record cleaning fluid, it is probably the closest to the original D3/4 fluid that is commonly available. If you can't source any of these PM me if you want to go that route.
