Does anyone know what the green stuff is on the screws...
Discussion in 'Exclusively Sansui' started by gkargreen, Oct 10, 2018.
  1. gkargreen
    gkargreen Active Member
    483
    Fairfax, VA
    and nuts on these Sansui's? I am guessing not a thread-lock compound, maybe a green lacquer to keep the nuts from coming off? Thanks
  2. Ronito6
    Ronito6 Super Member
    1,208
    picture?
  3. satellite
    satellite AK Subscriber Subscriber
    1,594
    Boise Idaho
    Maybe a mark to indicate they've been tightened to the proper spec? I've seen that before.
  4. DougBrewster
    DougBrewster AK Subscriber Subscriber
    548
    interference check for warranty purposes
    usedto and Bill Ferris like this.
  5. Hyperion
    49,840
    Hertfordshire, UK
    I think it probably is thread lock of some kind, it might just be varnish, but its purpose I think is thread locking. With the added benefit as Doug mentioned, that it would also disclose tampering. I've seen thread lock used in electronics assembly many times, and I particularly remember the thread lock we used to use (made by Loctite IIRC) being a dark green colour - it smelled vaguely of solvent, but had an 'earthy' kind of smell. ;)
  6. Gary Francks
    Gary Francks Active Member
    297
    John, you must be as old as me!
    Many, many years ago when I was in electronics assembly we used the very stuff that the OP talks about but for the life of me I can't remember the name!
    It was a form of varnish IIRC and came in red and green colours and was applied to screws and nuts after fitting up panels etc during mechanical assembly as a form of cheap and easily applied threadlock and to indicate that everything was fitted and checked.
    My heads going to hurt until I remember the name of the stuff we used.
    Smelled like nail varnish.
    Hyperion likes this.
  7. hugo454
    hugo454 Gold Member Subscriber
    1,632
    south florida
    Anthrax
  8. Blue Shadow
    22,263
    SE PA
    Thread lock in a apply after type. Jus to hold it a little.
    I use a bottle of nail polish, special color to do this and it identifies my gear so if it is sold on the bay and someone swaps a board...I got picture evidence which the bay would probably need to have notarized with the way they are siding with buyers of vintage gear and their 180-day return option.
  9. LBPete
    11,682
    Long Beach, CA
    Japanese manufacturing techniques of that era would often put a dab of paint on critical fastener to indicate they had been tighten. In some cases this step was added during production if inspections or warranty claims indicated a particular fastener was being left loose in production.
    - Pete
    Hyperion and Multimode like this.
  10. avionic
    46,474
    Fort Dodge, Iowa
    Magic blue smoke in its solid form..:biggrin:
    Blue Shadow and Hyperion like this.
  11. Pio1980
    Pio1980 AK Member Subscriber
    28,325
    Eastern Bamastan
    Seems right, basically green nail enamel.
  12. gkargreen
    483
    Fairfax, VA
    Thanks, everyone, that is what I am thinking as well, some kind of nail polish or varnish to hold nuts in place after assembly, I see this stuff all the time in Japanese gear both tube and SS amps/receivers that I have worked on.
  13. Pio1980
    28,325
    Eastern Bamastan
    I'm also thnking possibly qc inspector checking and sealing satisfactory work.
  14. 612electric
    612electric New Member
    28
    Sounds like loctite , we used to use the blue, which was meant to be removable, but they also carried a red and/or green for a more permanent thread lock. A few drops on the thread and then the friction of turning the screw or nut helped to solidify the compound.
  15. Pio1980
    28,325
    Eastern Bamastan
    They didn't use Loctite in electronix as a rule, just the clear green enamel-like dope.
  16. 604man
    604man Well-Known Member
    956
    Glyptal paint or known as "Glyp"
    I used to tune duplexers , and "glyp" was put on the threads after tuning.
    Bill Ferris, Gary Francks and Pio1980 like this.
  17. Pio1980
    28,325
    Eastern Bamastan
    Amber color in the U.S.
  18. squirrelnest
    squirrelnest Addicted Member
    7,445
    Alexandria, VA
    verdigris
  19. AudioWizard
    AudioWizard AK Subscriber Subscriber
    198
    Reno, NV
    When I was a Sony Preferred service station we could purchase the green translucent screw/nut retainer in a small bottle directly from Sony (it had a part #). I think it is lacquered based because dried very quickly and could be removed with MEK.
  20. bluesky
    bluesky Addicted Member
    7,670
    Shmegma.
    Bill Ferris likes this.
