Assuming it is, can't find a definite answer.
g..v Lunatic Member Jun 21, 2018 #2 If it sounds pretty much normal, it must be. RIAA curve rolls off high end.
WaynerN Addicted Member Jun 21, 2018 #3 If it has a preamp output, then it does. If it doesn't have a preamp output, then it does not.
Trekkie4 Retired Member Jun 21, 2018 #4 skbubba said: Assuming it is, can't find a definite answer. Click to expand... Straight from LP120's brochure: Phono Pre-Amp Gain: 36 dB nominal, RIAA equalized SOURCE
S skbubba New Member Jun 21, 2018 #5 Trekkie4 said: Straight from LP120's brochure: Phono Pre-Amp Gain: 36 dB nominal, RIAA equalized SOURCE Click to expand... Saw that. Wasn't clear to me if that meant just for the rca output with the switch set to line. The USB outputs regardless of the switch setting, but it makes sense now that it has to use the preamp.
