lionelbob
New Member
I've read through the many 4 ohm - 8 ohm posts here and they all pretty much say the same thing, if it says 8 ohms it means 8 ohms.
I grabbed set of Pioneer speakers thru EEK!bay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180069956782
When I got them home I noticed that they are marked 6 ohm.
The current owner had been running these with the 80 watt (cheapie) Fisher amp (marked 8 ohm) in the same ebay deal above.
The amp still works fine, and I ran it at 3/4 volume for 20 minutes without heat or failure.
What I was intending to do was to use the 6 ohm Pioneers with my 2230, but I got nervous reading all this stuff about roaching the trannys.
I remember from basic electronics class that impedence is not really resistance. ??
Some threads say to grab a 2 or 4 ohm 1/2 watt resistor and insert in series. Isn't that what a speaker selector box does?
It would seem that I could be pretty safe putting a 2 ohm resistor in series and just blast away.
I know, most of you won't say, "yeah go ahead," due to liability issues.
Or should I just put the Pioneers out for recycle?
