Driving a line level input with the preamp output
Discussion in 'General Audio Discussion' started by Olecranon, Nov 14, 2017.
  1. Olecranon
    Olecranon Active Member
    163
    Is there any issue or undesirable consequences with driving a line level input on a receiver with a variable level pre-out from a preamplifier? For example, is distortion higher?
    Am I fine if I match the volume level from the preamp to something connected directly to the receiver?
  2. petehall347
    25,048
    uk.. the middle bit
    unless i missed something it is the regular way it is done .
  3. I LIKE MUSIC
    I LIKE MUSIC Super Member
    Short answer, in general it will work fine.
    Longer answer, there are some that believe that anything that is added to the signal path (such as the ability to vary the signal level) will degrade the sound quality and the method of implementation of the variable signal can play a part.
    Source and load impedances may play a part depending on the design.
  4. Olecranon
    163
    Sorry, I should have been more clear.
    I have a pre-out from a preamplifier connected to a HT receiver line level input. The receiver also has a volume control. It's like daisy chaining two preamps together before amplification.
  5. petehall347
    25,048
    uk.. the middle bit
    yes it should work fine .
  6. E-Stat
    E-Stat Super Member
    4,977
    While that will work, a more traditional and simpler way to do that would be to use the tape output from the preamplifier to the HT input. That avoids extraneous controls and potential of overdriving the input.
    Gain is fixed and should be of sufficient level.
    ben_ likes this.
  7. onplane
    onplane What! No Wake???
    2,295
    Rochester, NY
    Yes, and each preamp will add distortion to the signal. E-Stat provides a much simpler solution... Rec Out to Aux In on the HT receiver.
    Further, depending upon your preamp, some preamps will pass the audio signal to Rec Out even with the preamp turned off.
    Regards,
    Jerry
  8. Kreshna
    Kreshna ...but I have to know.
    920
    Indonesia
    Out of curiosity: how bad is the distortion resulted from stacking preamps?
    And if you set one preamp to unity gain while controlling the volume from the other, would the distortion be still noticeable?
  9. sKiZo
    sKiZo Hates received: 8641 Subscriber
    Not true - you're adjusting the receiver's line level INPUT with the pre-amp output, and adjusting the receiver's OUTPUT with the volume controls. Oft desirable to give just the right signal level at each main leg of the audio chain. I also adjust line levels via software on the HTPC media server, and ditto on the DAC. A little tweak here and there can go a long way towards improving overall sound quality.
  10. whoaru99
    whoaru99 Epic Member
    40,664
    LoTL
    I'm sure it looks bad on paper.
    Of course, if one were to actually overload an input, yeah, that would result in something more meaningful.
    Kreshna likes this.
