Dual 1210 issue
Discussion in 'Turntables' started by Bill44, Nov 10, 2018.
  1. Bill44
    Bill44 New Member
    7
    Hi AK,
    My Noresco NC-341 (Dual 1210 on top) just started burning and I cannot see what burnt, is this a common problem and if so, how can I fix it?
    Thank you,
    Bill
  2. NoTransistors
    NoTransistors Dual Turntables Super-Restorer
    5,280
    Brooklyn
    Noresco must have been the Canadian subsidiary of Lucas.
    [Only a select few will understand this reference.]
  3. NoTransistors
    5,280
    Brooklyn
    Interessing.
  4. olddude55
    olddude55 AK Subscriber Subscriber
    712
    Joe Lucas, the prince of darkness. Although nearly ever AMT model kit I built back in the 1960s had Lucas lamps as a "custom" option.
  5. stereofisher
    stereofisher For the Love of the Music Subscriber
    4,312
    Southeast NY
    Without looking underneath...switch? Not normal.
  6. Bill44
    Bill44 New Member
    7
    I figured it was not a common problem, I think I may have found something wrong, but I am not sure, here is a picture of it.
    Also, anyone know a good and effective way of getting rid of the smell? I've had my window open for several hours and the smell is still here.
    https://drive.google.com/open?id=0BwszvhktYO0Ydktfa1NoWEdTOEhiOHdMUUNBMGI3ZWFOOWtR[​IMG]
    Here's the link, sorry about not realizing that it didn't work earlier.
  7. Patrice B
    Patrice B AK Subscriber Subscriber
    2,250
    Montréal, Canada
    Contact Klaus (DualCan) on VinylEngine. He's a former assistant manager at Noresco.
    BTW, your pic doesn't show...
  8. tnsilver
    tnsilver Super Member
    2,961
    Boston
    I can see it - but I'm not really oriented. It's too zoomed in. I need a better perspective.
  9. Bill44
    Bill44 New Member
    7
    Will do, give my a minute
  10. Bill44
    Bill44 New Member
    7
  11. tnsilver
    2,961
    Boston
    OK look, as far as I can tell, this is not a turntable issue but rather a driver amp PCB / power supply malfunction:
    Basically, this PCB with ancient components and rotten power lines:
    Fried resistors and medieval electrolytic capacitors:
    ...and cooked (bias?) transistors, and suspiciously scorched sections:
    Honestly, the entire PCB could use a rebuild, the ouput transistors need checking (prolly some are toast) and the power lines verified and replaced.
    It sounds like a major PITA and unless you have the skill to do it on your own, I'm not convinced it's financially viable or even worth it. Good news is,
    most likely, the nice turntable is probably intact and can be removed to it's own plinth and connected to it's own power supply. Many here would be
    able to assist if you separate the turntable from the amp carcass and re-designate the thread toward a stand alone TT.
  12. Bill44
    Bill44 New Member
    7
    I looked back at the areas that you have marked and determined that I am bad at taking these types of photos, I say this because the circle in the first picture is just a marking on the wire, as with the second photo, the top square is just a shadow which is the same for the circle in the third photo, the square marker is a reflection. Knowing this, is it still worth it to repair? (Also, I thought that the blue capacitor in photo #2 looked broken or busted or something). Thank you very much for analyzing these photos for me.
  13. Patrice B
    2,250
    Montréal, Canada
    Like tnsilver said, major PITA to restore and not worth the effort in my opinion. Just remove the TT and use it with another amp/receiver...
  14. Bill44
    Bill44 New Member
    7
    Given that the whole stereo part is an expensive repair job, I think I’ll either sell it on Kijiji, or run the turntable through my stereo, how hard would it be to separate the TT from the stereo?
  15. Patrice B
    2,250
    Montréal, Canada
    Pics of the underneath, the top and complete view or contact Klaus as he probably have the manual... Probably a couple of screws like on the usual Dual changers.
  16. Nat
    Nat AK Subscriber Subscriber
    12,915
    It's easy to remove. Loosen the two transit screws, tilt them inward, and lift up. You'll have to unplug the power cord, RCAs, and ground wire to get it out completely.
    You might want to save the cutout board the table rested on (or alternately, remove the amp electronics and use the case) since you'll need it, or a replacement, to mount the table in anything else.
  17. jlovda
    3,487
    NE Ohio
    As in Austin-Healey, MG, Triumph and Jaguar electrical parts
  18. NoTransistors
    5,280
    Brooklyn
    I owned two TR-7. As crappy as they were, the handling was superb.
  19. 62vauxhall
    62vauxhall AK Subscriber Subscriber
    2,083
    Their light switches had two position - Off & Flicker.
  20. NoTransistors
    5,280
    Brooklyn
    Jokes aside for the moment, I loved my little TR-7. Was a stunning little car with 5 MPH bumpers and 5 MPH frame rails and the best Jaguar/Rover 5 speed gearbox I have ever had the pleasure of rowing. The Tremec 6 speed box on my GTO is crap in comparison. But at least I have an LS-1 under the bonnet.
