Ishmael
Super Member
Until I saw our recently purchased Kenwood KA-7010 I had never known that Kenwood made dual power amplifiers. While I was aware of the Harman Kardon dual power receivers, and the high regard they are held in by many, I had never come across dual power in Kenwood.
There’s not a lot on the web about this amplifier, but in looking for more information I found pictures of the KA-7020 twin transformer amplifier (the KA-7010’s sibling?). By comparison the KA-7010 has four capacitors (I assume two per channel) rated at, 71V7500uf, while the KA-7020 has two capacitor’s rated at 71V15000uf, all Elna.
Opening up the KA-7010 I found a light coating of dust, but again how lucky, no evidence of a smoker as the dust came right off in my wiping cloth and swabs (yes there’s still some dust under the more delicate parts, maybe an air blast will remove them from there while I run my shop vac over the area? Just don’t want to bend/break anything).
I then broadened my search for information about dual power Kenwood’s and learned more about these models including the gold standard Supreme and Model 500/600 amplifiers.
The history and specifications for the Kenwood 500 at the Vintage Knob impressed on me what a superb amplifier it is. Therein was noted:
RMS Power: 2x 100w (8 Ohm, 20hz-20,000hz, 0.08% THD
Dynamic Power: 520w (4 Ohm)
S/N ratio: 110dB short-circuited
IMD: 0.08% (rated output into 8 Ohm)
Damping Factor: 50 at 8 Ohm
However, after Aker fonon (thanks again fonon) provided the specification sheet for the KA-7010, I was quite surprised at the quality, at least by measured specifications, that went into this black box amplifier(and it’s sibling KA-7020 noted separately below), for example from the KA-7010 specifications:
RMS Power: 100 watts per channel minimum, RMS, both channels driven, at 8 Ohms from
20 HZ to 20,000 HZ with no more than 0.06% total harmonic distortion (same
for KA-7020 except with 0.008% total harmonic distortion)
Dynamic Power: 125 W per channel at 8 Ohm KA-7020 140 W per channel at 8 Ohm
200 W per channel at 4 Ohm KA-7020 240 W per channel at 4 Ohm
270 W per channel at 2 Ohm KA-7020 380 W per channel at 2 Ohm
S/N ratio: Tuner/Aux/Tape – (IHF-A) (IHF 66) 110dB for 150 mV input
IMD: (60 Hz:7 kHz = 4.1) at Rated Output Power 0.005%
Damping Factor: 160/50 Hz at 8 Ohm KA-7020 220/50Hz at 8 Ohm
So now comes the subjective part. I hooked the amplifier up to my garage Sony CD player and New Large Advent speakers. I first cued up the Titanic Sound Track and played “Hymn to the Sea”. While my restored vintage JVC receiver is very good, this was much better. The movement between the orchestra and the (Scottish/Irish) pipes as they sang this instrumental lament was effortless and textured. When the deep tones of the oceans abyss were played they literally pressurized the garage. Next was Elton John’s “Rocket Man” detail, much more detail in both his voice and the bands contribution. Finally, Fleetwood Mac and “You Make Loving Fun” Christine McVie’s voice leads the band and the nuances to the words are clear, drum whacks and guitar plucks too.
Conclusion:
This is no numbed out black box amplifier. This is a beautifully executed musical tool which will engage you in the listening process. Due to its power your speakers wont’ need much to perform and 4 ohm speakers need not be avoided. You get lucky from time to time in this hobby of vintage gear as did we in this purchase. Now I wonder if I will ever see a KA-7020 surface?
Conclusion:
