Dumpster MCS 3207
Discussion in 'DIY' started by Punker, Jun 14, 2017.
  1. Punker
    Punker New Member
    43
    Hi I need help restoring and clean an MCS 3207.i am experiencing scratchy volume. What's best contact cleaner? How do I change blown lightbulbs? It might have lose wiring
  2. Mitkraft
    Mitkraft Super Member
    2,771
    Houston
    A search here will reveal your answers. For the scratchy volume you'll want some deoxit. Do a search on threads with deoxit in the title and you'll find one with step by step instructions. I'd also search lamp replacements and see if there is a thread about doing them on your unit.
  3. Punker
    Punker New Member
    43
    Thank you I wasn't able to find much information on my unit. Do you think I should replace the caps in my unit? Cause it hasn't been serviced in a long time
  4. Punker
    Punker New Member
    43
    Do you think it was an awesome score finding a vintage stereo receiver?
  5. Knucklehead
    Knucklehead The Village Idiot Subscriber
    293
    Central Washington State
    I know nothing about MCS stuff - other than it was sold by JC Penney for a time. And my younger brother had one for a few years. If you aren't hearing any unusual buzzing or crackling noises it might be fine. If you want to do something with it replacing the power supply caps is always a good place to start.
  6. Punker
    Punker New Member
    43
    Just some cracking I opened it up and the caps seem fine
  7. Punker
    Punker New Member
    43
    But I think that is due to the volume
  8. Punker
    Punker New Member
    43
    Who made the JC Penney MCS line of Stereo audio equipment? What is the equivalent model for my MCS 3207? Because I can't find any information on it
  9. Punker
    Punker New Member
    43
    Also the front lights on the faceplate sometimes don't turn on
  10. Lavane
    6,884
    northern cal.
    Does evrything but the lights still work? If so it may just be a bad solder joint in the lighting circuit, a flakey bulb going out or a faulty switch. Give it a few taps on top if the lights are out and see if they flicker or come on.
  11. Punker
    Punker New Member
    43
    Yes everything but the lights work. I went to an antique shop and I talked to the owner about my receiver and he gave me his service repair man number.
  12. Punker
    Punker New Member
    43
    I did and the lights do turn on
  13. faber12
    faber12 AK Subscriber Subscriber
    3,907
    Northwest Ohio
    Some of the MCS units were made by NEC.
  14. Punker
    Punker New Member
    43
    Thank you
  15. OMGCat!
    2,669
    Alhambra, CA
    Sounds like a little deoxit and some solder touch up will get you going again.
    I'd say it's definitely a great score finding a nice receiver anywhere but especially if it was going to be thrown away and you can give it some more life.
    I'd do some reading on how to clean it up. There are lots of opinions and methods. I generally use windex and then a quick detailing wax on the outside of my stuff. The inside it really depends on how dirty it is.
    As far as recapping, I'd listen to it a while and see how you like it. If it's acting up you can always do some reading and go through it at a later date. Typically you'd do more than caps so a bit of reading and maybe some practice on a junky VCR from the thrift store would be in order before jumping into something you like.
  16. Punker
    Punker New Member
    43
    Do you think I should call the antique dealers service repair man?
  17. Binkman
    Binkman Addicted Member
    6,257
    Raleigh, NC
    Welcome to the abyss of audio repair. without adding a bunch of bs.. .. do you have any idea of repairing or testing experience ? I write this because the unit itself might be best left alone and traded. :D
  18. Punker
    Punker New Member
    43
    It does work
  19. Punker
    Punker New Member
    43
    this the problem I am hearing
  20. Punker
    Punker New Member
    43
