Dust cap problem on Heresey ll
Discussion in 'The Klipsch Korner' started by ccawker, May 29, 2018.
  1. ccawker
    ccawker Active Member
    269
    elk river,mn
    Dented in and was looking at other posts and the "tape" thing nor the "vacuum" seems to work......someone had success with the KG2 as he just cut it off and reglued it,but the Heresey dustcap is not like those.
    Any suggestions would be helpful.
    thank you.
  2. silversport
    silversport Super Member
    2,521
    ChicagoLand-USA
    some have had success with a small push pin...piercing the dust cap and then manually pulling it to it's normal profile...remember this is only a dust cap and usually the dented look is the only issue with it being pushed in...good luck with yours... (When I tried this on a pair of Quartets...either the tape or vacuum way worked for me)
  3. Searing75
    Searing75 AK Subscriber Subscriber
    399
    Stronger tape? Or, the small pin method. I use old JBL’s for my guitar rig. The ones with the aluminum dust caps. They often get dented. It’s purely cosmetic, but it drives me nuts. Try real duct tape. Not the popular brand, but the actual metallic like, silvery stuff. It’s very Sticky and will work I bet.
    silversport likes this.
  4. nbndtrain
    nbndtrain Active Member
    460
    Denver, CO
    apply duct tape with a pencil eraser and let sit for an hour then yank straight back
  5. fernarias
    fernarias Super Member
    1,117
    Merced, CA
    Use a pick (the thinner the better and it's so useful for other things) if you have cloth dust cap. Just insert and pull the dust cap back into shape. Have done it with mine (people can't keep their hands off of tits).
    moray james likes this.
  6. AnalogBrad
    AnalogBrad AK Subscriber Subscriber
    97
    Chester NY
    One of the dust caps on my Heresy I is damaged. I bought 3" dust caps from PE which are too small. What is the proper size to replace the dust cap, and vendor suggestion? They will look a bit odd with the faded off-white cone and black dust cap, but that's not an issue.
  7. Hajidub
    Hajidub Chihuahua/Pug = Chug Subscriber
    5,622
    Colorado Springs, CO
    BTW the vacuum method works best if you have the end on the cover when you turn it on (most suction at the very beginning). If you can't use a pin to get it out just leave it and put the grill cover back on.
  8. Ramseybella
    Ramseybella AK Member
    860
    White Rock, New Mexico
    Know this is old. If you have a felt like dust cap that has a crease when you have pulled the dent. I dampen the cap with water then put a clip pin close to the dent. Pull it out hold the pin in place. Release the pressure the dent and crease gone cap looks normal. Have done this on four or five caps. Works.
  9. AlTinkster92
    AlTinkster92 AK Subscriber Subscriber
    3,342
    NC
    This tool is great for re tightening tube sockets as well. :)
  10. AnalogBrad
    97
    Chester NY
    To answer my own question, the 3 1/2" dust cap from speakerworks fits. I replaced the caps on both speakers, as they are the decorator series with no grills.
  11. KlipschFan61
    KlipschFan61 Smooth Jazzer
    982
    Manchester, NH
    My cat dug one of his feet into mine. I wasn't pleased.
