I think he was asking about the dust cover, but yes, cloth surrounds need to be treated for best bass. The correct sealer is sold by eBay seller vintage-ar or AK member RoyC. You can tell if yours need it by doing the "push test" - with the speaker on its back, carefully push down on the woofer while keeping it straight so you don't scrape the VC. If it snaps right back to its rest position, the cabinets are leaky, probably through the porous woofer surround, and so the woofer isn't operating as designed. If it "oozes" back over a period of a second or more, that's when you know it's right. (comments also apply to KLH speakers as well.)
AR pots are notorious for needing to be cleaned; you may get away with Deoxit but often they need to be removed, cleaned, then lubed with dielectric grease to keep the problem from recurring, and reinstalled.
