DYNA ST-70 Harmonic Distortion Testing using all 1960's Heathkit Tube Technology
Discussion in 'Tube Audio' started by JRUBIN, May 14, 2018.
  1. JRUBIN
    JRUBIN Active Member
    121
    Florida
    In this video I will demonstrate harmonic distortion testing of my Dynaco ST 70 amplifier using all Heathkit tube gear from the 50's and 60's. This demonstration will show the THD produced from this amplifier at 2KHZ using three different power inputs.
    The equipment used includes:
    Heathkit IG-72 Audio Generator
    Dynakit ST70 Power Amplifier
    Heathkit IM-12 Harmonic Distortion Meter
    Heathkit O-12 Oscilloscope
    The entire process is shown in the video over several iterations, some have been shortened
    Pio1980, Lavane and I LIKE MUSIC like this.
  2. larryderouin
    22,034
    Glen Burnie Md.
    Jordan; Do you know where I can get a copy of the IM-12 manual? I've got an IM-12 but no manual, and don't want to use it unless I have the manual.
    Thanks
    Larry
  3. primosounds
    2,927
    Terra, 21st century CE
    Hey thanks for posting the info. Always nice to see the vintage tools being used to good advantage.
  4. ConradH
    ConradH Addicted Member
    8,037
    Canandaigua, NY
    Nice! People underestimate Heathkit test equipment. It may not hit the numbers of the HP and similar of the time, but it gets the job done. You can easily fix it if it breaks and/or mod it for improved performance.
    drtool likes this.
  5. dcgillespie
    9,847
    Ball Ground, GA
    Nice job! That distortion reading correlates well with my own tests at 1 kHz on the ST-70. It would be interesting to know what the distortion is of the signal generator alone without the ST-70 in circuit. For any expected distortion reading, its always best if the source has an internal distortion level of no greater than 10% of the distortion reading produced by the device under test. In this instance then, the Heath generator would hopefully have an internal distortion no greater than .014% at the output level required to drive the ST-70 to 32 watts output, or about 1.25 vac rms.
    The old Heath test equipment was great gear at a very affordable price point. Thanks for sharing!
    Dave
    Retrovert likes this.
  6. s-petersen
    s-petersen Scott Subscriber
    4,728
    Middletown,New York
  7. larryderouin
    22,034
    Glen Burnie Md.
    Thanks Scott. Just what I was looking for.
  8. Audiovet
    Audiovet Well-Known Member
    674
    Pretoria, South Africa
    As Dave G said.
    I read that the Heathkit IG-72 specifies a typical distortion of 0,1%. This will only be when optimally adjusted, and not frequency-independant.
    Not to 'rain on the parade' (we need that here in South-Africa, not on the thread!), but that will need to be taken into account. Otherwise an informative thread!
  9. s-petersen
    4,728
    Middletown,New York
    I have upgraded from the IM-48 and IM-58 to the solid state versions IM-5248 IM-5258 and IG-5218(with the Morray? mod)
  10. drtool
    drtool It might get loud In Houston Subscriber
    2,210
    Houston Texas
    Thanks for the post.
  11. JRUBIN
    121
    Florida
    The THD from the test set into the alayzer was .12% at this frequency... I should have specified this in the video to reduce confusion.
  12. dcgillespie
    9,847
    Ball Ground, GA
    Thanks JR. Just goes to show how cascaded signals that each contain their own distortion elements can often produce a cancellation effect to produce less distortion in the output, than the simple addition of the two distortion products would suggest.
    Dave
  13. JRUBIN
    121
    Florida
    If two signals cancel themselves out in a forest, and no 331A is there to hear it..... Does it really make a sound?
  14. triode17
    triode17 Super Member
    1,374
    Side question for you. i have the later version, (in beige) of the same meter. Does your get extremely sensitive to case vibration at the 1% scale? My does and i don't know if this is normal or maybe a microphonic tube.
  15. s-petersen
    4,728
    Middletown,New York
  16. JRUBIN
    121
    Florida
    The audio analyzer is not the harmonic distortion analyzer... I believe that measuer inter modulation distortion, amongst other things.
