Hello all,
I just procured a set of Dynaco A50s, they were less than ideal but I have been looking for a while now and these were what worked out to get so far. I hooked them up to two different amps and have been having problems with them.
What I know from previous owner: Both tweeters were replaced with ones from a set of A25s. (I know that the A25 tweeters were not the same ones on the A50, but I have read that the tweeters from the A35s should be the same.) One woofer was replaced at some point.
The problem I am having with the speakers is that when they are hooked up and played, they are significantly quieter than any other speaker that I connect to the same amp. (I tried them with a 55 watt MCS receiver as well as a 100 watt Fisher CA amp, the fisher rocks a pair of Yamaha NS-9393 to ear splitting levels no problem.) This surprised me because a 55 watt amp plays my set of A25s louder than I would want them. The other problem is that one of the speakers plays noticeably louder than the other. They also produce a very small amount of muffled bass, and turning up the bass on the amplifier just turns the sound all mushy. I don't know if it was the one that was replaced, but one woofer appears to have slight coil rub when lightly pressing on it evenly. At this point I am feeling that there has to be something seriously wrong with this pair of speakers, I always loved the A25 and have lusted after the A50s since I got my first pair of A25s, but have found nothing but disappointment. Does this sound like a crossover problem that needs to be recapped? Could the wrong tweeters be throwing everything off? Any ideas or suggestions are welcome.
Thanks.
Thanks.
