Stonedeaf has described it well. To get the optimal effect, it's important that the rear speakers be at least as far from your ears as the front ones, because unlike Dolby or other modern surround systems, there's no rear-channel delay built in. Also, be sure that your amp has a common ground between channels, or you run a risk of damaging it. Well worth a try.
