I realize there is much information available on this little guy, but there are couple questions about this early model for which I have not seen the answer or a definitive one. For those that may be curious, mine is serial number 1399 and has a silver (or natural aluminum) engraved faceplate and has preamp input/output jacks.
My first question concerns the power supply board (P800). Mine looked like all the components were original, but resistor R802 was 1.2k ohms (per color code and approximate measured value upon removal) whereas the service manual I have indicates this resistor should have a value of 8.2K ohms. Would someone please confirm the correct value? The amp has been working for over 40 years with this installed, but I'm still curious to know. I do know Marantz Service Manuals of this era are known for many errors. The manual I have shows the preamp jacks in the photos and on the schematics so it has to be a relatively early version, but I'm also wondering if a change in value (for the better) may have been made after mine was built (refer to my final note about my phono board)
My next question is about replacing the H713 and H714 varistors on the power amplifier board (P700). I saw a thread on AK that recommended using one 1N4148 diode. This is what I have installed. Subsequently I have seen another restorer recommend two of 1N4148 in series and another recommendation to use a (or possibly a series of) 1N4448 diode(s) after measuring the voltage drop of the original part. The last sounds like the intelligent, scientific way to go, but I have already committed my originals to the garbage weeks ago so I can't measure them. I can tell you they were the "gob" type with a red dot on them. The service manual gives the number S3016R. I will look to see if I can find any specs. on this old part in the meantime, but if you may have the definitive answer from experience I'd appreciate knowing your results.
For those of you that may embark on restoring one of these early 1030's please be warned that I found many errors on the PCB's silkscreened labeling concerning capacitor polarity. Many capacitors were installed opposite of what was indicated on the board. Mine had all original caps when I purchased it and the amplifier worked, so I knew the silkscreened information was wrong. Please observe installed polarity before removing components and don't depend on what is printed on the board of these early models. I have seen photographs of these same boards on later 1030's where this information has been corrected.
Another note on this early model: On my phono board (P900) caps C909 and C910 did not have the resistors R936 and R937 installed in series with these caps to ground. This must have been a change that occurred after mine was built. It does show them in the manual I have and I did install them on my phono board suspecting that it was a running change for improvement.
Thanks in advance for any enlightenment.
