I finally did the comparison of THD with speaker cables of different length and parallel. I compare to the bare amp.
This is taken from the output of the amp directly at the output transistor before even the cable going to the panel connector. This is the true distortion of the amp. Test frequency is 20KHz, amplitude is 40Vpp which is about 50W into 4ohm. The load is 4ohm. You should expect the THD going down to half for standard 8ohm. The measurement is 0.0055% which is pretty good.
This is measure on the load end (eg. at the speaker) with only a 3feet long Monster type 12gauge cable. THD up almost 10 times to 0.048%. I have to say just going through the connector measure about 0.019%, so the cable add about 0.03%. But you get the picture.
This is measure at the load end with 10ft monster like 12 gauge cable. THD is whopping 0.14%. This already is a big cable and 10ft is not uncommon in real system. You see how bad the cable make?
This is adding a 6feet 12 gauge monster like cable in PARALLEL to the 10 feet cable. Look at the improvement of THD by paralleling cables. THD back down to 0.065%
I hope this convince people that keep claiming you don't need big cables for speakers. That they pull out some charts by some amp company and claim it's ok to use 16 gauge cable if it is short. I long experience cable is one of the utmost important thing in a good system. I don't want to repeatedly writing my experience when I first bought my JM Lab speaker that was over 3 times the cost of my Kef and not sounding better until I use 4 pairs of monster like 12 gauge cables on each speaker.
Also, how do you judge amps with low THD if the cable mask the signal with distortion?
