wow was I surprised by this! Rebuilt this amp carefully (at least the rebuild was done by looking at the amp and reproducing all the wiring according to the original build and following along the schematic...) but it is humming like crazy, there is about 1.4 v p-p on the screens and plate of the output tubes and at the input cap ( a new film cap of 35 ufd/500 v rating), the hum on the second cap is almost 0 v (a 10 ufd film cap) so it is all on the output tubes and 1st pole of the filter. Check the wiring against the schematic repeatedly and no errors I can see, there is some funky cross connections on the rectifiers using NC pins but that should not be an issue, also, the power tranny "bucks" (makes initial noise) on turn on even though there is a surge of only about 2 amps, it also "bucks" again after a warm up as the power comes up, afterwards it is as quite as can be. Anyone got an idea of what is going on? thanks!
