Eico HF. Will a power trans. from a HF-20 amp work on a HF-22?
Discussion in 'Tube Audio' started by buickguy62, Apr 15, 2018.
  1. buickguy62
    buickguy62 Active Member
    229
    Can I use a power transformer from a HF-20 integrated amp as a replacement on the HF-22 power amp?
    Thanks in advance,
    Tom
  2. soundmotor
    soundmotor super modified
    They are pretty close but you will need the SAMS to see how close.
  3. dcgillespie
    9,935
    Ball Ground, GA
    The power transformer between these two models are one and the same, even right down to the Eico part number, so swap away!
    Dave
  4. buickguy62
    229
    Great, thanks!!!!
  5. Ohighway
    Ohighway Wannabe Minimalist Subscriber
    IIRC the OPT is the same between the two also.
  6. soundmotor
    OK, I thought they were as well, knew the outputs were the same. Then hecked the schematics and saw minor diffs in PT sec resistance & voltages. They look like SAMS schematics too, what gives?
    HF-22
    http://www.freeinfosociety.com/electronics/schemview.php?id=2340
    HF-20
    http://www.freeinfosociety.com/electronics/schemview.php?id=2339
  7. drtool
    drtool It might get loud In Houston Subscriber
    2,215
    Houston Texas
    Make sure the owner b4 you did not swap out xformer. Links did not work for me Soundmotor.
  8. multichamp12
    multichamp12 AK Subscriber Subscriber
    559
    I do not always trust the sams manuals. Try to find the original Eico manuals. But as Dave said, you will be fine as they are the same transformers (as long as they are the actual originals)
  9. soundmotor
    Are you using Chrome by any chance? They work for Explorer & Firefox.
  10. drtool
    2,215
    Houston Texas
    Chrome.
  11. soundmotor
    I switched to Firefox last month and uninstalled Chrome. It would not display many links and I gave up trying to figure it out. On latest Windows 10 update.
  12. drtool
    2,215
    Houston Texas
    Thanks Soundmotor.
    soundmotor likes this.
  13. GordonW
    18,001
    Marietta/Moultrie GA USA
    Correct.
    Regards,
    Gordon.
