JohnW
Member
I am working on restoring an Eico HF85 preamp and want to change out the volume control.
The current control has two separate sections hooked together, one for each channel. This serves as both balance and volume controls. Unfortunately, it does neither very well.
I want to put in an ALPS RK27 dual pot, but don’t want to give up having a balance adjustment. I don’t really need the “MODE” selection, since I am pretty consistently “Stereophonic Norm”.
So, the plan is to remove the “MODE” and convert to a standard center detent balance control and change the “LEVEL” to a modern dual pot.
Currently the “MODE” is wired directly to “LEVEL” in the schematic. The “LEVEL” pot is 500k impedance.
Two questions:
1. Should the rewired volume control sit ahead of the balance control in the circuit, or after, or does it make any difference.
2. If the current volume control is 500k, what should the impedance for the new controls be: (500k Bal -> 500k Vol), (250k Bal –> 250k Vol), or something else?
Two questions:
