Eico ST70 w/external amplifiers
Dlav
New Member
Hello all, I'm building a set of 3way triamplified speakers. Im using my Eico ST70 tube integrated amp. I would like to use the Eico for midrange duties, and use 2 Hafler dh220's amps (1)for the low frequency and (1) for the high frequencies. The Eico has no line outputs for connection to the other amps. My question is,can I use the tape outputs on the Eico for the 2 hafler amps? If this will not work,I also have a hafler dh110 preamp with the typical inputs and outputs, can this preamp be put into the mix with the Eico to accomplish the triamp setup?
Thank you for your time...
You can use the Eico's tape outs to the Haflers if they have individual gain (and/or tone) controls. If the Haflers are just power amps then you can use the DH110 from the Eico's tape outs to power them.
