Picked up my ELAC AF-61's Friday. I was simply to damm curious about what A.Jones was doing with this speakers 200 hz down bass system ( sealed box/passive radiators/internally ported/multiple bass drivers and multiple passive radiators) . First off - lovely bass -tight ,crisp ,detailed and real authority. And no - they don't do dinosaur footfalls or hip-hop thumpa -thumpa - but ya wanna hear everything Ray Brown is doing -these will do nicely. The surprise for me was the degree of improvement in the mids/highs over the LS-50's that I've been listening thru for the last 8 or 9 months. The AF-61 co-ax mid/tweet is a marvel ( I think?? this might be the same part in all three Adante models ?) - exceptionally sweet n just plain linear over the range it covers. I have records that I've enjoyed for 40-50 years that I just thought had passages that screetched or rang at certain points . Thought these were part of the original performance -guess not. This isn't to say the AF-61 are the magic syrup that buries detail along with play back distortion - not so - I suspect lots of speakers have problems with powerful female vocals or horn passages just around the crossover point between the mid(s) and tweeter(s) ? BTW- really lousy recordings have no problem sounding really lousy thru these speakers (sigh:-( . the 61's throw a wide and deep image that any mini-monitor would be proud to claim.
At any rate -the Adante's are a pleasure to listen thru. Couple of observations about the tweeter - this changed from a metal dome a year or so ago to a really different looking not metal dome tweeter in the production units. there was something that looked like a sorta spider web protector in pictures over the dome -actually it's attached (part of ? molded as part of ?) the tweeter. Is this attached to the dome to control specific break up /resonance points on the dome ? Is anyone else building tweeters this way ? The other odd thing about this tweeter/mid is it's high in the cabinet - center of the tweeter is probably a good foot over my head when I'm seated . Is the dispersion of this driver really that good ? It SOUNDS like it ! Is the flare milled into the front of the cabinet around the mid/tweet part of the remarkable dispersion ?
Finally -get help unpacking them . They are large ,heavy and really literally slick -you need to turn them upside down to mount the base -grabbing the speaker connections might not be a good idea and there is nothing else on the cabinet to hold onto. Finally -there is a small plastic bag with six base mounting bolts in each speaker - I spent a certain amount of time looking for these and with both speakers -they just suddenly appeared on the carpet ? Watch for 'em.
