I'm still puzzled by this:
DAW Soundcard->marantz 2230->amp->speaker-> Good bass levels
DAW Soundcard->amp->speakers-> anemic bass levels
I can't find ANY information on such a situation, it seems nobody else notices this...
The amp input specs are:
input impedance: 50,000 ohms
input sensitivity 97mv/W
The soundcard output specs are only given as:
• Line level 8 x 1/4" TRS Jack
• Nominal output level 0dBFS = 16dBu, electronically balanced
• All outputs are useable as monitoring outputs
The 2230 specs are:
-input impedance: 100,000 ohms
So whats going on? Its an impedance problem of some sort, but I can't figure it out. Any help would be greatly appreciated, Ideally Id like to just run the damn thing straight to the amp but I can't because of the no bass problem
The 2230 specs are:
