smartin53
Well-Known Member
So I use quotes as I doubt I fit into most fancy Mc setups...and it's not actually elegant at all.
Basically, since I only use my MX120 as a preamp to my stereo, the TV in the basement is far away from the setup and the one RCA cable I have that reaches it is crap and introduces noise to the unit on all inputs when connected. It makes it a pain to make adjustments to the settings I can only access from the setup menu.
Luckily, I recently happened to get an old Sony Watchman Color to toy around with and it dawned on me that I could kill two birds with one stone. Instead of trying to run a long cable, I just scrounged my boxes of tangled cords and found a compatible mini jack to RCA video cable so I can access the menu as needed.
In addition, as I fiddled I remembered that I could just as easily run a cable from the output to the tuner input. Bam, now I have menu access and a tuner. It's not super high end but I don't need it for the menu and radio stations.
