xXSHADoW93Xx
Found this at the Salvation Army for $7. It's a two-speed, belt-drive, semi-automatic turntable which clearly looks like a cheap Technics knockoff. It has an Audio-Technica AT95 cartridge, but I tested it with my Pickering V-15.
It has a strobe and a pitch control, for both 33 1/3 and 45rpm, but is a PITA to get it to adjust properly
No info about the actual manufacturer, just a generic tag:
A peek inside:
The original belt was too stretched out, so I grabbed a belt from a scrapped Crosley. probably explains the bad WOW and flutter I get while adjusting the speed (but the wow and flutter goes away after a few seconds)
Despite its cheapness, it has an actual adjustable counterweight and anti-skate control:
Probably just going to keep it to test magnetic cartridges on.
A peek inside:
