Bauhausler
Rational Subjectivist
All;
This is the first step or two in an experiment with Altec 755E drivers. For those of you not familiar with this driver, it's a fullrange that originated with Western Electric. Many people consider the original WE version to be the best sounding full range driver ever made. They were used in the AR1 speaker, paired with the AR woofer in a sealed cabinet. The response of the 755E, a version from the '60s, is said to be from about 40 hz to 13khz. That's nearly high enough on top to satisfy my aged ears, but an octave short on the bottom, so I won't be running these fullrange. Right now I have a single one loaded in a 1.3 cu ft speaker box that I have adapted for this purpose by blanking off the midrange and tweeter holes and fabricating an adaptor plate to fit the 755E into the woofer hole. A pic of this setup is attached. I picked this cab, which is a bit small for the application, because bothe the back and front are fully removable. That makes modifying it a breeze. The material is good 5/8" plywood with nice walnut veneer and a fairly transparent permanent grillecloth. The box that you see has been stuffed with two sheets of foam aprox 12" X 24" each. They cover the sides and bend around the back to meet in the middle. This controls resonances a bit. The box is sealed. Theoretically, this size box needs a port to get the best bottom end response from this driver. I may go that route if I think that I can get enough bottom end to run them full range, but probably not. If I'm going to use a sub anyway, why bother fooling with the alignment of the main driver. Right now I have this box with the 755E sitting on top of a Cambridge powered sub, rolled in at around 55 hz. The 755E is running full range. I also have a Hiquphon dome tweeter paralelled with the 755E, just sitting on top to boost the top end. I have it fed through a 1.8uf film cap, which rolls it in at about 11Khz. The level seems about right without an L-pad. If necessary, and if I keep these cabs for the 755Es, I will install a good tweeter permanently in the existing tweeter hole. There's another 755E coming this week by UPS so I'll have a pair running by the weekend.
My initial impression is that there's a major excess of energy in the presence region (2000 - 3500 hz). It's not quite 'shouty' but way too forward for my taste. The bass is fine as low as it goes. I'm using a preamp, my Yamaha C-70, that has a parametric tone control section. I'm lowering the presence region by about 4db and that helps a lot. It also needs a boost in the 250 hz range according to my ear, but I like a warm bass anyway. this driver doesn't seem as 'open' as my Lowther DX3s. Neither is perfect, and I'll keep experimenting to tweak up the 755E.
This project might be the excuse I need to build the GM70 20W SET amp that I've been planning. Schem scribble to follow. That's just about the right amount of power for this driver and I really like the sound of DHTs and fullrange drivers.
