Kuch73
Looking to mount a Winegard 6010 on the peak of the roof and have a few ground questions. First, I know I should ground it and already bought some 8ga solid copper, a ground block for the coax, and some sealant for the connections. Can I run one ground for both the mast and the coax down through the ground block to the ground rod, or do I have to run two separate grounds? Also, I know this is for lightning protection, but to keep the connections from the elements, can I run them into the crawl space with the ground and back out, or leave everything outside? Thanks
