External phono stage better than YAMAHA A-S2000 phono stage
Discussion in 'Yamaha' started by steppen, Sep 12, 2017.
  1. steppen
    steppen Member
    70
    Salvador city Brazil
    Hi dear anyone experienced another phono stage better than the present in A-S2000?
    Not too expansive like Musical fidelity, Project , Vincent, Cambridge audio ?
    thanks in advance
  2. steppen
    steppen Member
    70
    Hi any inputs ?
  3. charles 1973
    charles 1973 Super Member
    2,934
    I would try the phono stage in the A-S2000. Honestly I doubt you will get much better for any less than 200 - $300. A decent phono stage isn't expensive to build into an amp unless you want that last 7% or so of perfect SQ. Even stand alone models, Like my $120 MM/MC Tonar-Vinyline (AKA - Project Phono Box) does an excellent job. As the AS-2000 is one of Yamaha's higher end amps, I would expect it too will do a fine job.
    The biggest advantage of a separate Phono preamp is it will allow you to move the TT much farther from the amp using the phono preamps RCA output instead of the cartridge. Especially if you are using a low output MC cartridge.
    steppen likes this.
  4. steppen
    steppen Member
    70
    Thanks Charles. I use a ortolan 2M blue in my Yamaha and I like it a lot.
    The next step is to use a MC cartridge to test.
    cheers
  5. steppen
    steppen Member
    70
    sorry , Ortofon 2M blue cartridge + project debut carbon dc turntable + Yamaha A-S2000 integrated.
  6. charles 1973
    2,934
    That's a fine combo. I use a Nagoaka MP 11 cartridge on a vintage Pioneer TT.
    Nagoaka cartridge's manage to extract the finest details on old and new LP's while suppressing surface noise. You might try their MP110 or MP200 when you have worn out your Ortofon 2M Blue.
    steppen likes this.
  7. boza
    boza Super Member
    1,239
    uk
    I would think the phono stage in the yamaha will be pretty good.
    Ma be a project tube box would be an option but I don't think it will be cheep to get better than what's in the as2000.
    steppen likes this.
  8. steppen
    steppen Member
    70
    I want to try the Nagaokas on my setup also, maybe the 2M blue are an analitical cartdrige. Maybe MP110. The MP 200 and 300 are too expansive for now.
    My wish list for the MC´S are Denon DL110 and Denon DL-103 (low output).
    Thank´s for the comments guys,
  9. avionic
    38,104
    Fort Dodge, Iowa
    Yamaha's phono pre-amps are usually pretty decent for both MC an MM.
    steppen likes this.
  10. steppen
    steppen Member
    70
    I will try soon an MC avionic and post my comments here,
  11. cairns4me
    cairns4me Active Member
    274
    Cairns Far Nth Qld Australia
    steppen....Please Do :)
    steppen likes this.
  12. steppen
    steppen Member
    70
    How about Vincent PHO-700 a tube phono preamp ?
    Anyone?
  13. steppen
    steppen Member
    70
    I also could try Tavish design “vintage 6sl7 phono stage “ its a great preamp i think
  14. luvvinvinyl
    luvvinvinyl Aggie! Staff Member Admin Subscriber
    25,233
    Windsor, Ontario, Canada
    Well, at about $700 for a new Vincent, you are moving into a fine tube phono stage. It has a great reputation, but you might only be getting a small improvement, other than changing from Solid State to tube. The A2000 is no slouch, so it will take some coin to better the performance. I guess you are willing to spend the money, if you are looking at a Vincent.
    steppen likes this.
  15. fernarias
    fernarias AK Subscriber Subscriber
    826
    Merced, CA
    Yamaha phono pre amps are always very good to excellent and the A-S2000 is excellent. If you want to spend more money then get a better cartridge instead like a Grado Red (same price as your Blue but better performance) or Nagaoka mp110(Nagaoka mp150 for the win). I would also recommend a good vintage turntable that has a better tonearm with more adjustments than the Carbon Debut and better speed control (wow and flutter).
    steppen likes this.
  16. steppen
    steppen Member
    70
    Thank you guys. I decided to upgrade my cartdrige first there is very good options.
    And save the money rsrsr
  17. Dr. Ear
    Dr. Ear Well-Known Member
    680
    Austria
    The A-S2000 phono stage is excellent - as long as the cartridge is a good match. The MC input impedance is fixed and unfortunately rather low (50 Ohms). This might be OK for some Ortofon cartridges. Other carts requiring a load of ≥ 100 Ohms, like the Denon DL301 might sound a bit lifeless. The same applies with MM input capacitance (200pF).
    steppen likes this.
  18. steppen
    steppen Member
    70
  19. fernarias
    826
    Merced, CA
    steppen likes this.
  20. steppen
    steppen Member
    70
    Looking yamaha MM and MC specifications i saw that’s hard to beat. Signal noise and THD are very good.
    Thank sinto advance.
