I would like for the community to take a look at my 2624 build to see if there any mistakes. After my recap I am having a tough time getting the unit to work. I am using a DBT with the 2624 out the unit will come out of protection. with it in the unit will stay in protection mode.
What does the underside look like? What unit is this unit for? Did you set the VRs for min bias and min offset for the testing? What are the blue and gray wire voltages going to the protect board?
What does the underside look like? See picture What unit is this unit for? 9090DB Did you set the VRs for min bias and min offset for the testing? What are the blue and gray wire voltages going to the protect board? Blue unstable, Gray ~ 60V
The device is just the 3 diode solution is series. Didoes are covered in heat shrink then glued to a metal terminal then encased in epoxy.
Whoa! Is it safe to turn a 9090db on without F2624 in it? I just posted a new thread about what a mess F2624 is in a 9090db I just got that won't come out of protection. If I can trouble shoot any other potential protection issues with F2624 out that would be awesome. This is the first I've heard of doing that despite a long morning of AK 9090db back-catalog reading.
yes, in fact it's a pointer to other issues if there are any... Just be double sure that when you reinstall the 2624 that it isn't one pin off. That causes other problems.
@joe camilli your board appears intact in regards to component orientation. I've verified semi-conductors and resistors. I hope the red lead on your STV-3H replacement device is the cathode (-) and the white is anode (+). If you got 60VDC on the gray lead under the PS board it's full rails voltage and that means something is terribly wrong. Check the power transistors on the back of the unit - verify one or more are not shot! Stay on DBT (I hope you're powering up the unit using one). BTW: That R34 sure looks like it suffered heat damage and John already pointed out to a possible reason. It doesn't matter if it checks good, the circumstances aren't. You need to be very careful with the bias trimmers settings when you power on the unit. Are the LED's doing anything on power up?
I suggest checking TR15, TR16, TR17 and TR18 to make sure the lead placement is correct. Hard to see, and not knowing the type of transistors you inslalled, but most modern transistors in a TO92 case are pinned as BCE, or ECB. You 4 transistors appear to installed with the C going to the base connection on the board, which would mean that the B or E connection is incorrect as well.
There appears to be a lot of solder on the top side of that board. Is TR12 bridged on the bottom of the board? When I had an issue with voltage on the gray/blue wires, it was a bad TR05 or 06. Then after replacement I had a hell of a time getting the unit right because of the effed up SM and that crap about the bias and offset adjustments and the channels they go with. Just knowing that section of the manual is messed up but good, it is what caused the TR to pop in the unit I did, helps. You need to have the bias all with way down when powered on until it is adjusted. Find the correct diagrams here on AK for that. The offset should be set to a good setting also. If you have the old VRs and know which is which you can get the reading from them and set the new ones to something similar and see if you can get that 60V (you on a dim bulb, I got 47) to come down to operating level.
What about those open holes on the board for different lead spacing components? Shouldn't those be filled with solder? It looks like in some spots there isn't going to be a lot of copper connecting the traces.
R34 has been replaced. Another clue with the F-2624 installed none of the front panel lights come. Remove the board and they all come. Obviously in the process of recapping i messed something up - need some more tips on troubling shooting. Wife is wondering what happen to a simple project..........
The cool thing about F 2624 is the mirror image, I spent some time comparing resistance and diode measurements between both sides at various points, which helped me isolate some issues. Trace the diagram to find resistors that isolate a section of the circuit, lift the bridge leg then measure and compare. It prob goes without saying, but testing components in circuit vs out may not reveal issues. The lights not coming could be related to a short. If the draw is too great maybe theres not enough voltage to supply the lights... Did you rebuild the power supply board as well? With board removed do you have tune and signal strength needle movement on AM of FM? See what kind of voltage you're getting with the board removed vs installed and you'll know what kind of draw the DBT is picking up
it's looking relatively good from the underside, except it's contaminated with fibre/cat fur/hair so I can't really tell if the traces are fractured, but there appears to be some nasty scratches here and there. You may want to reflow the solder pads with fresh solder and verify all those black leads in the grounding corner section. If that doesn't make a difference, we're gonna have to go back to the driver amp and verify each and every transistor integrity.
