Factory riser dimensions for Altec 15
Discussion in 'The Lansing Legacy' started by analoged, Sep 21, 2018.
  1. analoged
    analoged New Member
    13
    Hello,
    Hoping someone here could give me the dimensions of the factory installed riser for Altec model 15.
    Just picked a pair up that doesn't have them.I'l try to make pair.
    Thanks in advance.
  2. sinnerboy
    sinnerboy AK Subscriber Subscriber
    215
    NW NJ
    Bear with me here. I have a pair of Model 15's that I bought from an estate sale. They need a restoration, they have been on the back burner for a couple of months. A few weeks after I bought the speakers (along with a LOT of other HiFi equipment), the daughter of the collector contacted me and had a few more things if I wanted them. With a variety of miscellaneous things were some speaker stands. I didn't think much about them but took them anyway. Now, based on your request, I'm thinking they might be for the Model 15's. Looking at the pics on the web, they certainly could be. The measurements are 18" square, the back height is 3", front height is 1 1/4". I attached a pic below. Let me know if you think these are authentic. Thanks
  3. 62caddy
    9,968
    NEPA
    Not Model 15 bases. They weren't sloped.
    Katalyst and sinnerboy like this.
  4. twiiii
    twiiii Addicted Member
    6,742
    west Texas
    Call Great Plains Audio in OK City, OK.
  5. bowtie427ss
    bowtie427ss arigato gozaimashita
    17,365
    Land of Milk & Honey Boo Boo
    20 W x 13-3/4 D x 1-1/2 H made from the same 3/4 inch MDF as the rest of the cabinet. Painted black.
    EDIT: correction, only the edges of the riser are painted. The outer surface is a textured laminate of some sort, probably melamine. It's the same material/finish used on the risers and collars between the LF and HF sections of models 14 and 19.
    They also have feet/glides on the corners of the riser from the factory. Nearly white in color, i think they're nylon, 3/4 diameter, about 1/4 inch tall
  6. analoged
    analoged New Member
    13
    Thank you for this detailed reply.
    cheers,Ed
  7. bowtie427ss
    17,365
    You're welcome!
    Note that the riser is not centered, but rather pushed forward with only about a 3/8 inch setback from the front of the cabinet.
  8. 62caddy
    9,968
    NEPA
    @bowtie427ss - you don't happen to have an extra foot pad laying around by any chance do you? One of my 14s needs one. Thanks.
  9. bowtie427ss
    17,365
    I'm sorry 'caddy, i don't. The 14's i have are currently still a slow work in progress. They were in very bad shape, yet priced accordingly.
    When i got them, they were already missing both risers. So, i'll be looking to someone like yourself to verify that the 14 used the same or similar pad/glide as the 15.
    Apparently, at some point in time one of the tangerines became dis-mounted. This usually results in a very intense and annoying buzzing from the horn. Previous owner saw fit to remedy the situation by simply removing and discarding the tangerine. "You probably don't need those pesky things in there anyway". ;)
  10. Fat Point Ja
    Fat Point Ja Active Member
    260
    The bases on my 15's rotted out, Altec's particle board bases just don't last 40 years. I replaced them with some arrow head/spikes. It cured the vibrating noise I heard when they were cranked.
  11. 62caddy
    9,968
    NEPA
    The bases will definitely be destroyed if they are allowed to get wet, otherwise they should last indefinitely. Mine are still in perfect shape except for a small area where the black applique strip had pulled away from the particle board. Probably a result of the speaker being dragged on carpeting.
    Bases can easily be fabricated as needed.
