Fairchild 275 Pair on Auction site
Discussion in 'Dollars and Sense' started by multichamp12, Oct 2, 2017.
  1. multichamp12
    multichamp12 AK Subscriber Subscriber
    488
    Leland47 and radioactive like this.
  2. Pio1980
    Pio1980 AK Member Subscriber
    25,100
    Angel Station, Alabama
    Par with McIntosh MC75 pair?
  3. radioactive
    radioactive tube gear fanatic Subscriber
    8,353
    winnipeg , manitoba
    Nice amps.
  4. radioactive
    8,353
    winnipeg , manitoba
    And then some.
  5. sheltie dave
    sheltie dave Addicted Member
    6,876
    St. Louis
    I would side with better, as well.
  6. Pio1980
    25,100
    Certainly simpler, if Mullard.
  7. multichamp12
    488
    My dream system would be those 275s and a Fairchild 248 preamp, or a Pilot SP-216!
    Crestwood23, Leland47 and radioactive like this.
  8. Pio1980
    25,100
  9. biscuithead
    biscuithead Me likes the eargasm retroplasm... Subscriber
    4,173
    Northern Colorado
    I have always wondered this also. Can you expound on this a bit...? I am not a "mac or nothing guy" but when it comes to old tube amps, I have always been impressed with the Mac transformers and their "less than 1% THD at rated power" ... Is Fairchild similar? I haven't looked up their specs yet...
    Edit: Just looked at specs for the 255... can't find 275. just under 2% at full rated power.
    No disrespect meant to the Todd Transformer, but isn't this twice the distortion to a similar Mcintosh amp?
  10. multichamp12
    488
    Does anyone know if Mac use C core transformers like Fairchild did?
  11. sheltie dave
    6,876
    St. Louis
    Mac wound their own proprietary transformers, so they were not specifically c core.
  12. radioactive
    8,353
    winnipeg , manitoba
    Fairchild 260 manual and specs can be found here along with a writeup and test data for the 275 can found here .just search fairchild.
    http://akdatabase.org/AKview/index.php?cat=2
  13. Pio1980
    25,100
    multichamp12 likes this.
  14. biscuithead
    4,173
    Northern Colorado
    Thanks! The Fairchild 275s look very similar to the MC-60s of the same period, as far as distortion curve. Impressive. Add to that, their rarity.... I understand their value. I hope to someday hear one. Curious of original cost ?
    radioactive likes this.
  15. multichamp12
    488
    Original cost of the 275? Probably close to $200.
    Original price of the 260: $149.50
    Original price of the 255: $89.50
    Fairchild 240 preamp: $98.50
    biscuithead likes this.
  16. Crestwood23
    Crestwood23 keep on chooglin' Subscriber
    1,654
    North Jersey
    Sure wish I had $5k just laying around, these would the perfect match for my 248 pre.
  17. Pio1980
    25,100
    Dunno how the Marantz 2, 5, 8/8B, and 9 compare.
  18. Crestwood23
    1,654
    North Jersey
    Well I suppose the main difference is EL34 vs 6550. So far I haven’t heard a 6550 amp that I like better than my 8b, but I’ve only heard Quicksilvers and a nice pair of restored MC60’s. But something tells me these 275’s ain’t yer average 6550 amps!
  19. sheltie dave
    6,876
    St. Louis
    The 8B is a little more rounded, and softer on drum leading edges. I would say the Marantz reminds me of a French pointalism painting, with lots of delightful tones and pistaches of coloring, while the Fairchilds are a Dali painting, a little mind bending in what they can produce, hypnotizing you to follow all the quirks and rabbit holes you thought a tube amp would never take you, especially in the bass nethers you had reserved only for solid state amp.
    I could use all the key words the reviewers parlez with, but to me a great amp is more about how it sets your frame of mind and physical state. A great wine, a fantastic meal, a rich beer, and a fun jazz album all take you someplace in multiple ways...for me, so does a great amp. These, along with the Mac MC30, are some very, very fine vintage glass.
    Crestwood23 and radioactive like this.
  20. radioactive
    8,353
    winnipeg , manitoba
    Your better off comparing it to a amp that uses the same output tube compliment which has already been said. If you want to use the marantz's that you listed try those are more on par with the output power and tubes that they use.
    Fairchild amps are a good example as as all of them used either 1614/(6l6gc) el34/6ca7 except the 275 but they didn't all start out using that tube compliment and changed it up from the 255 to 260.
    When the Fairchild 255 came out it used a pair of 6l6 for tubes and power was rated at 25w. Then the 255a came out and the power increased to 30w using a pair of 6ca7's. The 260 originally used a pair of 1614 metal output tubes which are basically a 6l6 on steroids. The tube was mostly used in rf applications and allowed them to get the '50w claimed output. They then came out with a modification called the 260r revision which then allowed you to use 6ca7 /el34 tubes.
