Raul
I don't know if this has already been discussed before, but in Voice of Music 1428 and 1448 amps (I don't know for other models because I only own these two) when playing a stereo track if you press the "mono" switch you don't have a real mono output because it blends only one channel in the two outputs so what is on the other channel is lost in reproduction.
To fix it you simly put a jumper between two wires in the mono-stereo switch to actually blend both channel together, an easy quick fix. Thanks to Dadbar and Beatcomber for letting me know about it and how to fix it.
