Ive spoken with the owner and Im replacing those two resistors with ceramic 2 watt as opposed to the original. Resistor swaps aren't a big deal on these amps because nobody really cares about that 'theoretical resistor sound'..... yet....
I have rebuilt two Heathkit T4 Aural Signal tracers to test such a theory....Ahhh, but there is no magical sound from carbon composite resistors except on the plate resistors, and even then it isn't much. Just guitar mythology that won't die.
The varistor effect of CC only shows up with voltage swings of a few hundred volts, because it's about 8% at the high end. Constant voltage just gives you a poor quality (out of tolerance) resistor that's a bit lower than it should be at that voltage. R.G. Keen thoroughly and totally debunked the mojo here:
www.geofex.com/article_folders/carbon_comp/carboncomp.htm
CC resistors also have lots of waterfall noise and it doesn't make the amp sound good, just noisy.
Science!
At best extremely subjective..... especially when Ive found that the noise perceived was in fact coming from a 12ax7 - and this was proven beyond a doubt from a tube swapout. My post shouldn't be taken out of context, I don't believe in Mojo. people want original parts, I want to see values on test equipment.You mean the noise theory? Or the Vcr theory? Both? Neither? Something else?
Results?
Yes, those two are very close. More changes came in the '70-'77 A1270 Silverface, like phase inverter grid leak resistors dropped from 1M to 330k. That change is also penciled in in the AB868 schematic. So that is one thing I checked in mine. I have circled the 1M resistors in the picture in post #14 above.As far as I know, the only circuitry difference between the original blackface and later silverface Deluxe Reverbs, is that crazy 1200 pico-farad disc cap in the output stage. Easily removed.
http://ampwares.com/schematics/deluxe_reverb_ab763.pdf
http://ampwares.com/schematics/deluxereverb_ab868.pdf
