Rea Mochiach
New Member
Hi-
Got an AR XA in pretty wonderful condition, however, the headshell was Glued with Gorilla glue into the tonearm plastic sleeve since the Plastic 'nibs' were stripped at a time when there were no after market solutions.
I bought off eBay a new AR XA headshell and i want to install it.
Right now the Glued headshell works fine.
1. What's the best way to get the glued shell out?
2. Should i just leave in the Glued shell instead of risking ruining the arm sleeve?
Next question:
The motor makes a bit of noise when starting up, as if its stressing a bit to pick up speed. Should i help it manually to pick up speed(it does not make the noise when i do that), or is it designed to perform better if it picks up speed without manual help?
Thanks!
Next question:
Thanks!
