After waiting 5 yrs such that the Executive was originally in BugleGirls Hands, then I became it's caretaker a R2R was missing from the Unit. Oh Yeah, I managed to fit in a AKAI GX-4000D and then an AMPEX 960 within the last 6 months was installed with good results. But I wanted the 1250. Thru the good graces of a few AK'er's, one of whom had this unit and put it up on Bartertown as a Free to good home, one who let me know about it, and the other who donated the shipping costs, I now am the owner of an AMPEX 1270 Portable(yeah Right) R2R. It has the speakers inside, but the stereo amp (6AQ5 SE) was removed prior to my getting it.No Problem with that. The plan is for the 1250 Deck in it to be installed in my 1963 FISHER Executive Console, in place of the model 960 from 1957. The Motor on the 1250 is dated Aug, 1959 (Howards Brand motor). It does have the 1/4 track playback head, and 1/4 track recording head, and 1/2 track Erase head. The 1250/F-44 Fine Line Deck is the correct one for the '63 and '64 Executives.
Overall the cosmetics are very good (8.5 to 9.0 of 10) except for a number scribed into the faceplate below the takeup reel.
I haven't pulled the deck from the case yet. I DO know that all tubes except the 6X4 are removed. No problem as I have a boatload of 12au7's and 12ax7's.
The plan is to replace the CAN CAPS with HH's, and replace the power supply DUAL Selenium Diode, Replace out of spec resistors and then do a recap of the preamps. Old Stock 12AU7's, 12ax7's, and replace the 6x4 if it shows weak. Clean and reoil all motor bushings, shaft bushings, lubricate all slide areas, and check all of the Rubber tires on the idlers.
The Heads look to me to have minimal wear, but I'll get a closer look later. The tension roller and the pinch roller look to have minimal wear, so I believe that this 1270 is a low mileage unit. I'll get new AMPEX BELTS and possibly new playback head (depend on how much) from a retired AMPEX Guy in the Midwest. I may ask him about the amp. I can probably install the 960 in the 1270 case and use it that way once i get an amp for it.
This thing is HUGE! I guess it would be considered "portable" for the Early/mid 60's @ approx 50lbs.
dimensions of1270
I'll try and take some pics of the dis-assembly from the case on Fri-Sat. btwn Dr. appt's. I'm anticipating that this will drop in
dimensions of1270
