Finally Fixed My Fisher KX200
Discussion in 'Fisher' started by tube-a-lou, Mar 5, 2017.
  1. tube-a-lou
    tube-a-lou Super Member
    4,424
    If you guy's have been following a few threads awhile back, I've been having bloated bass issues
    with my KX200. When I used to play it I would only keep it on for a half a hour at most because
    of this issue, so I finally took out the .082uf caps I had in the amp and replaced them with a quad
    of Spraque Vitamin Q's .068uf after having them in a few days I have to say the bass is more
    on the neutral side now and now I been playing it for a least two hours at a time sometimes three.
    I know the common thing to do is put .1uf's in the amps for increase bass but this amp doesn't need
    the increase it has it all so I now sit and enjoy it.
  2. vince_pgh
    vince_pgh New Member
    19
    Good job, Tube! Did you replace the power cans and/or increase their value?
  3. tube-a-lou
    4,424
    Yes it was all done when I first restored the amp, I just had that nagging bloated bass issue which seems
    better now with the .068uf Caps.
  4. Westy56
    Westy56 A symphony of paradox
    6,611
    Abq, NM
    Hey Lou, does someone make drop in replacements for the can caps?
  5. larryderouin
    21,601
    Glen Burnie Md.
    Westy; Try Hayseed Hamfest. He'll make custom Can's to your specification. About the cost each as CE Generic Can's @ AES. I've done all my Fisher's with his can's and no problems with them since 2009. He's now making kits for the most popular models.
    http://www.Hayseeedhamfest.com
    Larry
    Westy56 likes this.
  6. Westy56
    6,611
    Abq, NM
    Thanks Larry, good to know.
    I like the amplifier so much I purposely removed the cans so I wouldn't blow it up before restoration.
  7. tube-a-lou
    4,424
    Like Larry said, I also use AES caps the which seem fine as well.
    Westy56 likes this.
