I finally felt comfortable digging into my very early 500-B and installing a individual bias adjustment board. Took a little expert advice from Larry to get me there, but now it's done. There was no place on top or out back on this chassis to mount the board, so I did away with the test points on the board and mounted under side.
Not only is this receiver eye candy, but the sound is over the top too. Pretty odd to see the 7591's in front of the OPT's and in their own oven so to speak (early versions had them this way). All the more reason to make sure they run cooler. After a total recap, new diodes, new rectifier, screen stability resistors, sampling resistors, LED lamps, and a so so batch of two different pairs of power tubes, all is good. Before installing the IBAM, the tubes were running in the .50V range so it made it impossible to use confidently. Now I have them doing around .34V and I'm quite pleased with the results. This is one of cleanest receivers I have, and quite the time capsule sporting all original small tubes.
