Finding a 2238b relay replacement
dav808
New Member
Hi
I'm trying to figure out the relay in my 2238b. Doesn't seem to be the typical MY or LY hole/pin type.
I posted pictures of the board socket (sorry bad photos).
The red X's indicate that there's no pin under the relay to be soldered.Take a
Take a look at the pins pattern.
On the relay cover it says ''DEC TYPE MS4U 24VDC''
In the service manual the realy is listed part# LY40240050
Can you help me find a replacement
Thanks
-David
Going by the relay # you provided that came out of it an Omron Relay MY4-02-DC24 I believe would be the equivalent.
sui-san
Thanks sui-san,
for some reason I was only looking at the Omron MY2.:scratch2:
I think your suggestion will fit the socket.
Good day
I recently replaced the relay in my 2252B. The part number listed in the service manual is the same as yours (LY40240050). I used MY4-02-DC24 as a replacement and it worked fine.
Relay at Digikey
Relay at Digikey
When you got the new relay am i right in saying you had to snip off the pins that aren't soldered of the new one to match up with the old relay?
