My 101 st recap went well the amp sounds great ,however i have a tone balance issue the r channel seems louder with more base...This was also an issue before the recap..any ideas?
1. Cold or bad solder joint.
2. Speakers are out of phase.
3. Component is out of tolerance.
4. You say it "seems" _____. Put it on a scope to verify your observation.
5. Problem with cable/jack in signal chain
Do all the controls (slide switches included). If it has a loudness control, you could have a bad component in one or the other channel. Either the cap or the resistor.
