Odizzieus
Member
I just picked up a fisher 200t today for $28 dollars at an estate sale. The phono input and aux both work, but when I switch to the FM input with an antenna connected, the signal is barely audible at full volume. The signal strength meter works, but the stereo light never shows, likely just because it needs to be changed. There is no loud static, and FM muting is off. I have cleaned all the potentiometers with contact cleaner, and the issue persists. Any help would be appreciated
Also, the signal is still quite regardless if I have the unit in stereo or mono
