Work is well underway, with all the electrolytics in place as per the pictures below. The 100 ohm screen resistors (with their bus), the 10 ohm cathode resistors, 200K ohm grid resistors, and the 0.1 uF 630VDC IC MPW output tube couplers are all also in place. I put in a CL-80, visible in a couple of the shots (had to replace the fuse holder as well, believe it or not) and reworked the bias supply with new 1000 uF 35VDC caps, leaving the silicon rectifier bridge in place. As per the above posts, I replaced both of the 0.01 uF 600VDC tubular caps around the power transformer: the PT primary line-to-ground ("death") cap with an 0.01 uF X1/Y2 rated disc (orange) you can see, and the other (in the PT secondary) with a straight 0.01 uF 630VDC film tubular. I also replaced the two 0.01 uF disc couplers in the pre-amp 12AX7 stages with film caps.
For this rehab, I am using Drew Boice' IBAM design (I had the parts on hand) after using Dave Gillespie's design for all prior Fisher work. The picture shown are taken after all the above work, but prior to the IBAM installation. The nice space where I removed the old 2x1000uF bias cap will be the home of the IBAM. C42 (100 uF), R34 (2.2K) and R35 (1K) are unused and are all removed, per Drew's recommendations.
So, here are some shots of the tubular electrolytic installations. I used axial tubular replacement caps instead of radials--personal preference. By the way, I replaced all the cans EXCEPT for C56, the hot can (cardboard covered) 100 uF 300VDC doubler cap, which (believe it or not) easily passed the max working voltage leakage test on my Sprague TO-5 checker. The other two cans (C52 and C57) had at least one section that failed the leakage test and C57 was visibly leaking electrolyte.
Here's the bias supply with the much smaller modern 1000uF 35VDC caps installed and the silicon bias rectifier bridge re-wired in a more compact configuration. You can see the CL-80 installed in a PT primary leg. As per above, the 100uF cap and two resistors are not used and have been removed.
Below are the replacements for the C57 can (200uf 300V, 2X50uF 250V). I used 47 uF to replace the 50 uF sections, as these are well within the tolerances of the original units. As you can see, the 220 uF 300V replacement for the C section is a pretty good size cap. The 220 uf and one of the 47 uF caps are grounded where the 25 ohm speaker resistors are grounded. The other 47uF 250V is grounded to a can take of the original C57. Hopefully I'll get away with this without buzz/hum.
You can also see where I mounted the replacement for C52B (40 uF 400VDC), which decouples the tone control 12AX7 plate supply, the (mis-) labeled 390V supply (I think the 320V and 390V B+ points are switched on the Fisher 400 late model schematic). I used 47 uF caps to replace all the 40 uF sections of C52. This one is mounted directly to the "390V" B+ tie point for the tubes, with the minus on a nearby chassis ground point.
Below are the other two replacements for C52C and C52D (40uF 450VDC and 40 uF 500VDC respectively). I used 47uF replacements of equivalent working voltage. In this view, you can see the orange replacement for the 'death cap' as well. The D section 500VDC replacement is for the screen supply and you can see the positive end connected to the end of the screen supply bus for the output tubes (more on that below). The 450V axial next to it is the replacement for C52C (40 uF 450VDC), which decouples the phase inverter/PI plate supply, the (mis-) labeled 320V supply on the schematic. These two are grounded to the original C52 can tabs.
Here is another view of the C52 C and D caps showing where I added a two-point tie strip in addition to the single-point tie already in place for the B+ resistor string of R40 (1.2K 1W), R39 (2.2K 1W), and R38 (22K 1/2 watt). The purple and orange wires visible connected take the respective B+ voltage to the decoupling electrolytics that are remotely mounted (C52B above and C52A, below).
Here's the replacement for C52A (20uf 300V), mounted remotely with the + connected to the single plate tie point for the 12AX7 pre-amp tubes and the (-) connected to a nearby grounded tie point. I used a 22 uF 350VDC cap as the replacement for C52A. Also shown are the two film couplers added to replace the 0.01 uF discs in the pre-amp tubes, as recommended by Larry. Note that the replacement for R33 (100K 1/2W) is installed here, just below (and across) the electrolytic and grounded to the same tie point.
