Fisher 400 no FM mono
Discussion in 'Fisher' started by curtsad17, Aug 11, 2018.
  1. curtsad17
    curtsad17 Member
    73
    Media, PA
    My 400 is sounding wonderful but I have no FM mono output. I replaced the suspect 1 uf in the MPX and corrected the eye dance. In mono the eye retracts and does react to tuning but modulates a little. If I had to guess ( remember I am a novice) I would think the issue is after or R28 which does not leave much including the selector switch.
  2. Dave451
    Dave451 AK Subscriber Subscriber
    1,303
    Philly area
    Have you replaced C41, 8uF cap in ratio detector circuit? That one should be done as well.
  3. dcgillespie
    9,905
    Ball Ground, GA
    If you've got a good FM Stereo signal in both channels, but no mono signal in either channel, then it's doubtful that the problem is the selector switch. More likely, at some point in the path of R28, the signal is either broken, or shorted to ground after R28 (on the selector switch side). I'd wiggle and poke about that signal path -- as you say, not much otherwise that can cause this.
    Dave
  4. curtsad17
    curtsad17 Member
    73
    Media, PA
    It was a bad solder joint R28..
  5. Dave451
    1,303
    Philly area
    Well spotted!
  6. dcgillespie
    9,905
    Ball Ground, GA
    Glad you found it!
    Dave
  7. Tim D
    Tim D AK Subscriber Subscriber
    1,529
    Melbourne, FL
