Fisher 400 - One Speaker Cuts off when using AUX Tape Input
Discussion in 'Fisher' started by totsuka, Nov 28, 2018.
  1. totsuka
    totsuka New Member
    25
    I run a cable from my PC to RCA jacks in back of Fisher 400, but audio cuts off on one speaker after about 5 minutes. The other speaker continues to play. It only happens when I use this set up. I tried a new cable and the same thing happens. I was using this set up on my Fisher 500C with no problem. It's just music that I'm listening too off youtube.
    Any ideas?
    Thank you
  2. thornev
    thornev Well-Known Member
    753
    Mid Hudson Valley, NY
    Does the same thing happen when using other RCA jacks? Have you tried a different RCA cable? What if anything else are you doing besides listening to youTube on the PC when the speaker cuts out? Thorne
    PS - I just realized you have a 400. I'm not familiar with the jacks on that unit. Usually AUX and TAPE are different jacks.
  3. 1rebmem
    1rebmem AK Subscriber Subscriber
    175
    Wilmington, NC
    So FM stereo works fine for example?
    If true, I'd think your selector switch contacts need cleaning.
  4. totsuka
    totsuka New Member
    25
    Yes, and I hooked up the same cable to my Motorola Smart phone and listened to Youtube for 2 hours with no problems. Something about hooking up to my laptop causes the Fisher to shutdown audio to one channel. Odd
  5. dcgillespie
    9,894
    Ball Ground, GA
    Try the same set up using the Tape Monitor inputs and see if the same thing happens.
    Let us know!
    Dave
  6. Winters
    Winters Active Member
    265
    Poland
    The selector may have gotten dirty. Or there is a bad connection somewhere.
  7. Catmanboo
    Catmanboo AK Subscriber Subscriber
    606
    Atwater, ohio
    problem may be in the source & not your amp.Your phone worked , right? Dead giveaway, imho.:)
  8. dcgillespie
    9,894
    Ball Ground, GA
    Did you try the Tape Monitor inputs and setting?
    Dave
