Hello all....
I have a Fisher 400 that I purchased locally. We have a very well thought of tube gear repairman here in Knoxville, and I was told he went through the unit by the seller.
Upon inspection, it does seem to have been recapped with decent caps (Nichicon Muse/Poly) in all of the expected places. I just finished up some new 8 Ohm dummy loads, so I have been going through and "checking" actual power output on some of my collection.
The unit begins to clip at about 13Vrms, which seems correct into an 8 ohm load (approximately 22Wrms) but there is a pretty decent sized crossover distortion blip and one side has a ring in the transformer as power levels get towards clipping. The biggest problem seems to be a discrepancy in the output voltage between right and left channels. If i move the balance pot so that both voltages are equal they both seem to track fairly well, and begin to clip at the same time.
I could spend my time going through things again, but thought a quick post might get me on the right track sooner.
Thanks in advance...
Speed
Speed
