Zepman69
New Member
I have a 500C that has had a lot of work done in the past, new caps, adjustments etc.
Anyways, when I moved into my last apartment, the first time I took it out, only one channel seemed to work until the volume was around 11 o'clock. You could still hear some faint noise in the left channel, but it would really turn on at 11. When I DO get both channels working, I get some pretty bad distortion.
I opened the bottom panel up last night and did some tests on the volume pot. There appears there are no dead spots, but the resistance peaked about 75% of the way, and dropped off on both sides. That seems weird to me.
This happens with all inputs. If it isn't the volume pot(which I was planning on removing and rebuilding this weekend), what else can I check? Output tube voltage when the amp is turned on?
