Hello, first, thanks to all who answered my questions regarding my rebuild of the A-69 hybrid. I now have questions about a 60 monaural console. I rebuilt the chassis replacing all electrolytics, paper caps and any out of spec resistors (about 75%). All vacuum tubes read "good" on my budget heathkit tester. All inputs sound fine, including AM & FM. I power the chassis through a bucking transformer which brings the line voltage down to about 116VAC. Transformers don't get too hot, output tubes don't red-plate. Everything seems fine except the voltage on the anode pin of V-10, an EL84. If I clip my voltmeter to the pin, on power-up it will read correctly, but then diminish down to 0 volts by the time the tubes warm and the music sounds. The reading on the other EL84 is fine throughout, at a steady 337v. I have included a copy of the schematic as well as the voltage reference values. My recorded voltages are in red print, the red asterisk indicates the reading I'm having trouble with. All readings were taken with a digital voltmeter, on FM input, volume at low, bass at low, and treble at high as intructed. I appreciate any and all troubleshooting tips. Thanks.
