Thanks, I have very low volume on one channel unless I select mono, then it seems normal as far a volume on both channels. I have DeOxit all pots and seems to make no difference. Are the pec's your referenced a possible culprit?
If controls, switches, and socketed transistor leads are clean, then having volume equalized when in mono would indicate that the weak channel problem is ahead of the mono switch as the signal MUST be the same on both channels at that point.
Connect a jumper between pins 1A and 1C on the preamp board. Mode selector in STEREO.
1 - If the channels are balanced, the problem is ahead of that point.
2 - If they are now unbalanced, the problem is in the mode selector, reverb jacks (check and clean the jumpers) or REC or TAPE jack wiring. Check R19 - R22.
If the result from the above is (1) then, remove the 1A-1C jumper, mode selector in STEREO, and connect a jumper between pins 1D and 1M on the preamp board.
1 - If the channels are balanced, the problem is the source selector switch, input jack wiring, or program source itself.
2 - If the channels are unbalanced, then there is a problem on the preamp board.
While the tone control PEC could have the typical problem, it is after the MONO switch, so is not the direct cause of the unbalance.
