Hi all, I actually have a pair of these, one I bought and one given to me to fix up. The first is working fine, nice AM and FM reception as well as great sounding! However, the second is super weak and I can only get anything out of the AM section right now, nothing from the FM section. Unit has been recapped and I have started with the back end first as most of the front end voltages seem to be fine or close (a bit high compared to the working unit with its original filter cap...). So right off the bat V12 is waaay funky, pins 6 & 7 having no voltage whereas on the working unit there is the proper 32/55 vdc on them, respectively (should note the working unit is slightly different as to have the MPX output on it but that does not affect the circuitry of the output @ V12). I have checked the resistance of all the resistors affected (R433, 46 & 47) all are good as well as cap C60, all measure in-circuit the same in both circuits. Any suggestions? Thanks.
