UNLESS you've done the Phase Inverter mod on the 800c, DON'T USE RUSSIAN TUBES IN Phase inverter. See "400 Service Bulletin" in the Stickies Sub-forum. This applies to the 800c but it's not as critical. I've tried EH's, Tung-Sol's, and Sovtek 12ax7LPS there and they all go into cutoff. Use a Domestic Tube there or do the mod, which is listed in the "400 phase inverter mod" thread in the SUB-FORUM STICKIES.
Also if it's undergone an alignment leave the V1 thru V6 (RF AMP/Mixer/Oscillator/ IF STRIP) alone, except in the case where a tube goes dead. Then replace with GE RCA or Sylvania Rf/IF tubes.(See below for 6aq8) No need for expensive foreign tubes in the RF/IF stages as they don't affect the SQ. As for the 12ax7's, I've seen Fisher Branded Sylvania 12ax7 tubes in some very late production 800c/500c/and 400's. Fisher went with Sylvania tubes in a fair amount of gear as their stocks of Telefunkens ran out and the replacement costs went up. Sylvania's were less expensive and didn't change the sound of the units appreciably if at all. As FISHER changed over to S.S. tubes became a loss leader, and they went with the lowest bidder.
The only units that came with TELE 12ax7's (that still had original tubes in them) were my consoles. I find that TELEFUNKEN's, just like other manufacturers tubes have sections that become unbalanced (one reading approx 1/2 to 1/3 of the other) and are about useless except in extreme cases. I have a stash of domestic tubes with closely balanced sections, even if some are below minimum gm or emissions that perform better than those with unbalanced sections. With the exception of the V2 tube, all of the RF/IF strip tubes are single section tubes.
The V2 tube is a 6AQ8 (Dual TRIODE) which is used as the OSCILLATOR/MIXER tube. A weak section can cause problems in that the oscillator or the mixer section is weak, causing poor performance in the tuner. In 9 of 10 units with the 6AQ8 in the Front end of the tuner the 6AQ8 has at least one section that is barely operating and in some cases so poorly that stations cannot be received or highly distorted. The 6AQ8 in most all FISHER tuners is run hard and put away wet. So it IS prudent to replace this tube with a new either "NOS" if you can find one for a highly inflated price, a used one for about $20.00 or a good Used 6DT8 for 1/5th the price of a used 6AQ8. If you can find EUROPEAN EI 6AQ8 (ECC85) get them. they are a good tube at a decent price. (about $6.-$8ea). Otherwise the 6DT8 is a good sub.
