I also own the CA-880, and one thing to check first, is the fuses in the back. If the right channel fuse is blown, it may just need a simple replacement. If the original fuse is blown, and you replace it with a new one and the new one blows, the right channel amplifier block (chip amp) is shorted, and needs to be replaced. The CA-880 uses two mono STK-0080 80 watt amplifier blocks. You can still find these all over the net.
