Fisher cabinet reproduction - which one would you recommend?
Discussion in 'Fisher' started by cchean, May 31, 2018.
  1. cchean
    cchean Super Member
    1,386
    Charlotte, NC
    Looking for a cabinet replica for my Fisher X-1000 and KX-200. Although an original one would be nice, the reproductions that I've seen seem better build and sturdier. There was a seller on ebay that used to sell them, but I am not sure if he is still making them anymore.
    I am aware of a few AK members that build cabinets, but they are focused more on Pioneer and Marantz gear and they don't offer Fisher cabinets at all. Does anyone know of someone that I don't? Please share your commments on this. Thanks.
  2. dsndblm
    dsndblm AK Subscriber Subscriber
    993
    Central Arizona
  3. Sam08861
    Sam08861 Well-Known Member
    579
    Northwestern NJ
    This is a very easy DIY. 4 rectangular pieces of wood and one cutout for the vent.
    bolero likes this.
  4. Sam08861
    579
    Northwestern NJ
    ps.. I can dig up and post the cutting and cutout measurements if you decide to go that route. Cost is ~$50 including veneer and fancy feet.
    One correction to my prior post, there's 3 cutouts. One on top and two on the bottom for venting.
  5. Kingfisher
    Kingfisher AK Subscriber Subscriber
    822
    Western MI
    I have mcintoshcabs building me two cabinets right now for both my Fisher 400 and Scott 355 (tall G cabinet). It's kind of pricey, but they are supposed to be rock solid. I sold off 2 Pioneer SX-850's to raise money to pay for it. Fellow AKer Craigtone bought my Bose 551 Spacial Control Receiver since I'll never have the time to replace literally 100's of capacitors in each of these monsters. A Fisher 400 with a beautiful walnut cabinet and a few other pieces of gear.....my version of "Spacial Control" ;)
    Sam08861 likes this.
  6. davros
    davros AK Subscriber Subscriber
    213
    Winston Salem NC
    Sam, I would be interested in the cutout measurements. I've always wanted to try my hand at making a cabinet. I have a console pull KX-200 looking for a forever home.
  7. notdigital
    notdigital AK Subscriber Subscriber
    2,307
    NYNY
    CC: Didn't you have a cab for that X-1000?? It was in a little need of TLC if I recall.
  8. Dadbar
    Dadbar Super Member
    1,896
    Waltham & Gloucester MA
    I have two cabinets built by Mcintoshcabinets. They are nice...but they lack the patina of the vintage cabinets that I've gotten with other gear.
  9. larryderouin
    22,394
    Glen Burnie Md.
    Patina grows with age. Old cars with worn paint jobs didn't come that way from the factory, they aged and wore down. You weren't wrinkly, sun damaged and aged when you were born, so why expect a NEW cabinet to be that way. Let it age. 10 years from now it'll have some patina.
    bolero and tnsmnichols like this.
  10. notdigital
    2,307
    NYNY
    My sentiments as well. They are exquisitely made but look too new when contrasted to the piece that is housed in them.
  11. Sam08861
    579
    Northwestern NJ
    Davros,
    Sorry for the late reply, I'll dig thorough and find the cut sheet I gave to home depot, that has all the measurements or redraw it when I'm back home this weekend.
    Dadbar,
    While I wouldn't personally recommend doing this to Mcintoshcainet's incredibly beautiful enclosures, the below is a shortcut that might be helpful. Also, if there's any poly/varnish on the cabinet, that would have to be stripped or sanded anyway, risking damaging the veneer.
    https://pixiedustpaintcompany.com/products/pioneer-wood-diy-patina-quart
  12. Sam08861
    579
    Northwestern NJ
    I could not find my drawing, so redrew it... See below
    I had home depot make one long cut to get the depth and then 4 more cuts to get the panels. Took him less than 5 minutes and they didn't charge me anything. All I had to do was cut out the vents on top and bottom with a jigsaw.
    One word of caution, if you buy a pre cut vent screen on top, don't cut the top vent until you get and double check the measurement. I made my own out of a pattern metal sheet also from home depot.
    https://www.homedepot.com/p/M-D-Bui...-Nickel-Mosaic-Aluminum-Sheet-57005/202525460
    I added a 1/4" square wood dowel to the front face as seen in a photo of the finished product close up below to match one of the more rare factory cabinets. This was my 1st foray into woodworking so I wasn't smart enough to miter cut the dowel like I did the veneer behind it. Although a lot sloppier than I could do on a 2nd try, it still passes the 2 foot test pretty easily
    Covered in cheap iron on oak veneer that was available ins store at home depot ($15 for 2' x 8') and feet were ~$7-8 bucks for all 4 from china via ebay.
    something like... https://www.ebay.com/itm/40x20mm-al...435730?hash=item2cd57f1212:g:8TIAAOSwlfxXFgvm
    You will also need rails on the bottom to ensure the bottom clears and the faceplate is vertical. I cut a 99 cent yard stick and glued two 10" strips along the bottom. Ensure you test fit before gluing as the front 3-4" need to be clear.
    Also, the cabinet is about 1" or so deeper than 'stock' but I did that as it give some protection to all the stuff plugged into it and the ibba board is out of the way.
    Finally, you can also look at page 12 of the owners manual if you want to secure the cabinet to the chassis (screw hole locations to match bottom of chassis). I didn't for 2 reasons. 1... I like being able to slide it out to check on tubes, etc. 2... it would have required me to counter sink the machine screws from below so they are flush. Feet would resolve the clearance issue if you don't care.
    bolero, tcdriver and Archguy like this.
  13. Sam08861
    579
    Northwestern NJ
    Here you can see the feet and the matching plinth for the turntable. Same veneer sheet and MDF board.
  14. Sam08861
    579
    Northwestern NJ
    Davros,
    Just realized after doing all this, that you have a KX-200... if you send me your faceplate dimensions and depth of your chassis. I can easily re-do the drawing to fit your unit.
    Sorry about that, but maybe this will helps someone else.
  15. Archguy
    Archguy Official Roiurama Factory Rep Subscriber
    2,300
    Richmond VA
    Now that's what I call co-ordinated! And now I want a classic Fisher again.
  16. Sam08861
    579
    Northwestern NJ
    Davros,
    Ok, found the kx-200 owner's manual with the dimensions... I think this will work for you. I don't know if a top vent is needed or not for the kx-200, but kept it in the design.
    Took the faceplate dimensions and added 3/4" all around. Cutout dimensions on bottom are from the owner's manual. Same comments above for finding the screw hole locations and owner's manual pages updated as well.
    ps... not drawn to scale as the 500b diagram is. Also, looks like the depth will give you 1/4" beyond the back of the chassis, so may want to go 13.5" for the depth if you want some extra room.
  17. DavidJB
    DavidJB New Member
    16
    Norfolk, VA
    Have to start somewhere. Would anyone know of somebody who makes wood cabinets for older Harman Kardon receivers? I have a 930 I'd love to find one for. Thanks.
  18. davros
    213
    Winston Salem NC
    Thanks Sam, Greatly appreciated. This will be a fall project, so this will all go in the file. Thanks!
  19. lopezluna
    lopezluna AK Subscriber Subscriber
    71
    San Diego, California U.S.A
    Sam08861 very nice of you to take the time to post these measurements. I too have a kx-200 that needs a wood cabinet made for it. Question I have is how do you do the cutout on the top board for installing the mesh? Thanks again for contributing. Ben
  20. Sam08861
    579
    Northwestern NJ
    Hi lopezluna,
    If your question is about how I went about cutting the hole, I first drilled a hole near one of the corners with a 1" spade bit, but anything more than 1/3" or so should be good. Then I used a jigsaw to follow the outline of the cut I had penciled on the unit. Should note that I did this after veneering, and got nice clean cuts and edges due to the bond between them. Used a router to round the corners a bit, but was completely unnecessary.
    If you're talking about making a cutout to slip the edges of the mesh into, I didn't do it this way, but I think theres a dremel or router bit that can take care of that (I suspect you could use a grinding disc). Recall seeing a thread about it. What I did was bend the edges and left 1/2" tabs in five or six places to drive small wood screws through and secure to the cabinet so that the top of the mesh was flush with the top panel and also the cutout opening. Cut the mesh with one of those Wiss metal shears from the local borg.
    lopezluna likes this.
