i've been doing a variety of things to get ready for my coming fisher 400, including reading all i can about refurbing it.
i found the attached document on this site: http://www.hhhyde.com/music/fisher.html called "fisher doc restore instructions". i made a .pdf out of it for convenience.
i read through it, and laid it against the information actually found on that site, and most of it matches (hhhyde seems to have gone higher on voltage values, while keeping capacitance values on point). however, there are some things the fisher doc recommends removing altogether, or changing the value of from original, that i am curious to hear peoples' opinions on:
• removing resistor r94 (bias supply shunting resistor) to bring up the negative bias voltage to -20 to -24;
• removing l102 and l103 from the multiplex chassis (these are the 19kc filters);
• decreasing the resistance of r63 from 47K to 39K or 41.2K for accurate mono de-emphasis
• decreasing the resistance of r222 and r223 on the multiplex chassis from 27K (or 22K, depending on the original) to 16K for accurate fm stereo de-emphasis.
i understand there are valid reasons for not sending him any equipment for repair, or perhaps even avoiding him for the purchase of resto-paks, but that's not at issue here. i am concerned about his actual recommendations. are they valid? are they accurate? are they advisable (i.e., will they do what he suggests they will?). i guess it comes down to knowing whether he's actually a doc, or a quack.
thanks.
thanks.
